What codes can clear their self
Old 06-30-2008 | 08:50 AM
dscogin's Avatar
My check-engine light has come on a couple of times but dissappears after a day or two. I'm guessing, because I don't know what code was registering, that it is the gas cap. I had the check-engine light come on before 3 times before due to a misfire and the dealership had to clear it each time. They changed the #4 sparkplug and the check engine light hasn't come on and stayed so I think this self-clearing issue is definately something else. I just can't get to the dealer before it dissappears and everything returns to "seemingly" normal operation.
I know the remote start wont work when the check engine light is on. What else does the computer change when that light is on?
Old 06-30-2008 | 10:40 AM
Cokeybill's Avatar
I had the engine running once by remote start and when I got in, I put the key in and cranked it . I ended up with the engine light coming on. I shut it off and actually had to get out of the car and close the door and then did the start thing again to get it to clear. My little problem that I had.
Old 06-30-2008 | 11:16 AM
GCarp's Avatar
I've done that before too with no problems...No light or anything.
Old 06-30-2008 | 11:19 AM
GCarp's Avatar
Even if the light is not on when you bring it in, there should be stored codes.
If I remember right, the minor stuff like gas cap not on right, code will clear after a certain time frame (mileage?) if there is no repeat.
HotHHRSS
08-30-2009 07:49 PM
Black Beauty
05-17-2007 06:07 AM
RUDEINC
10
08-31-2006 06:18 AM
EZ4U2CHere
10
07-07-2006 05:06 PM
Quick Reply: What codes can clear their self
