Wheel Hop
Originally Posted by en0oNmAI
I have owned a few front drivers and have never had as much trouble with wheel hop as I do with my HHR. Anyone know of any ideas to help reduce this? My HHR is lowered already, and I have tried dropping the tire pressure (doesn't make sense to me since they are stock tires). Any input would be greatly appreciated! Thanks!
1) My HHR is lowered, and I'm certain this has reduced my wheel hop quite a bit (see #2).
2) The stock HHR suspension has nearly 7-inches of travel - that's a lot!) I'm sure the first 3-inches are very soft (as it is a progressive suspension), to soak up road bumps. This would account for a great deal of the hop you are experiencing.
As far as solutions, lowering is obvious. If you don't want to lower your HHR, you might try installing some spring spacers to stiffen the rates. This will obviously stiffen your road ride also, but it should cure the hop problem.
Just wanted to address this further for you...
[QUOTE=SoCalHHR]Jason, I thought about this much while I was on a road trip Friday, and realized 2 things:
QUOTE]
Hey Mike
Thanks for the help but if you read the 2nd or so line I am already lowered. Bought the springs from your website! I will get some video up here as soon as I can to show the hop, does this site accept WMV's?
QUOTE]
Hey Mike
Hey Sindy,
Need another combo thingie done here. Here's the other thread.......
wheel hopping problem
Thanks!!
Thanks!!
