Where is the knock sensor on the Ecotec engine?
It is bolted on the front of the block, right above the starter. You have to be underneath the HHR to eyeball it. Its wire terminal connects to a main wiring harness pigtail connector that is mounted to the dipstick tube.
arclightzero
06-16-2010 12:20 PM
