Whine with engine off
My sons old cavalier z-24 did same thing. Research found out when 1 of the 3 diodes goes in the alternator it will whine even with engine off. Disconnected battery and changed alternator. Problem solved. He had around 130k miles on it. Hope this helps.
Well it's not easy to say. I do know that the car performs test when the car is at rest like testing the o2 sensor heaters and what not. But the tests don't take all that long and don't usually make a lot of noise.
Goose
01-22-2010 10:02 PM
