Whistle sound after Hahn Charge Pipe Install?
Ok so I changed my oil and finally put on the hot side piping yesterday. I was sure to make sure that all the piping was clamped down to the best of my abilities. Now under boost (5lbs+) I get a whistling type noise.
Is this boost leak? The car feels pretty normal so I was thinking I would loose a lot of performance if I had a leak?
Any help would be great, I have read that sometimes the air flowing thru the pipes can make a noise but this is somewhat loud, def noticeable.
Any ideas?
Any ideas?
The whistle you are hearing, is the bpv, you should hear a little something like a whistle. Try just giving it a little pedal then. Let off. Should be a little whistle, as the system bleeds pressure. You should also be able to hear the turbo spool up now as well.
if you're boosting 5 psi under than you probably have a leak, i'd go through all the connectors and spray them with some WD-40 or PB Blaster and move them around and maybe then they will seal properly. it doesn't sound like you have a very large leak, i know when i cracked my IC i couldn't boost at all.
Hope this helps
Hope this helps
No it is boosting up to 15lbs (before my retune I was hitting 22lbs but thats another issue) I had my Dad power break it and you can only hear it when you are away from the motor, aka I believe it to be the air simply flowing faster and in different way than the stock pipes making it whistle.
Car still pulls hard and holds boost so after reading a bunch of diff threads Im going with the theory that it's simply the airflow.
A boost leak would kill performance right?
Yes a boost leak will cutback on performance. I think chevyguy just misread your post. Abs plastic is great for sound reduction, so is the 3/16 neoprene tube. By going with metal piping you lose a lot of turbidity and the thinner wall allows for better sound transfer. If you change out the cold side you will hear even more,.
Most people pull the bumper to install cold side, it can be done without pulling the bumper, but I recommend undoing the two bolts holding the radiator bottom in. this will give you the extra room you need. It is a little bit of a contortionist job to wiggle in the pipe but can be done. The front sway bar gets in the way a bit, and removing the vacuum tube from up top is a knuckle buster. Takes about two hours, , most of that is spent making sure it's not backwards.
