Wind noise with sunroof open
When I first got my car, I noticed a lot of wind noise with the sunroof open. Upon further investigation, I found the cause to be the factory deflector! I wanted to remove it, but that's impossible without drilling/breaking something. My simple solution was to jam a ball point pen between the roof and the deflector. It prevents the deflector from popping up when you open the roof and doesn't alter or damage anything. It's a little hokey, but it works and you can't see it at all.
You need to take care of not using it, Hte deflector is there for a reason. It keeps the air out of the car and it also helps protect the roof liner.
Air can get in and do damage to the interior if your not careful.
They make plastic sunroof deflectors that stick to the roof that will help remove the noise. They just stick on with 3M tape.
I was never a fan of the way they look but they do work to remove noise and air.
I should have mentioned that I also crack the rear windows when I open the roof. That makes the wind go up and out the top keeping the buffeting and the debris away :-)
If you restrict the height to about half of normal, it reduces noise but still keeps the air off the interior, using a tie strap ( zip tie,wire tye ) it allows the screen to open and close normally but only pop up about half way.
Hyperv6,
You are right about the plastic wind deflector. I put one on HHRvey 3 years ago, and it took care of the noise. My deflector came from the AVS company, and has a sleek, sporty, look to it. If I can figure out how to post a picture, I will do it. However, I will have to wait until the sun comes out so the picture will show up. It is very rainy here this morning.
When I bought HHRvey back in '06, I was also told by the dealer to crack the rear windows about a 1/2 inch when riding with the sunroof open. I have been doing this ever since and it really does help with the wind noise as well.
PS Can someone tell me how to upload pictures? I am not tech-saavy and I searched the site, but the only thing I could find about pictures was in the gallery. I wanted to know how to show a picture in my posts. Thanks for the help!
I know the plastic deflectors work well. But personally, I think they look hideous. They not only spoil the lines of a car, they always somehow seem to cheapen it.
