Window controls not working.
Old 05-08-2022 | 03:34 PM
Hvymax's Avatar
Currently the window controls only work on the door they are on except the passenger rear that doesn't work at all. The drivers door controls as well. The mirror controls work so I don't know if I have a switch issue or a wiring/connector issue?
Old 05-08-2022 | 04:03 PM
greg8453's Avatar
The drivers controls what as well. Just itself? The master has both it's and the other doors on a common ground. It is a redundant ground so it is possible one will work and not the other. The most likely fix would be to replace the master. The passenger rear may have it's own issues.
Old 05-08-2022 | 05:14 PM
Clean the contacts, I see you found that thread.
Old 05-08-2022 | 09:52 PM
The window lockout switch is in the right position?
Old 05-08-2022 | 10:28 PM
greg8453's Avatar
We need a like button. Good thought.
Old 05-09-2022 | 06:36 AM
Hvymax's Avatar
Yeah tried every which way.
Old 05-09-2022 | 06:46 AM
Did you clean the master switch?
Old 05-09-2022 | 02:15 PM
greg8453's Avatar
Are these serviceable?
Old 05-09-2022 | 03:25 PM
Hvymax's Avatar
I'll probably pull the door panels when I get the 6x9 speakers for the back doors.
Old 05-09-2022 | 04:06 PM
You don’t need to pull the door panels for the 2009 and up LS/ LT
read this thread., post #5 and on
https://www.chevyhhr.net/forums/how-...ontacts-62119/
Quick Reply: Window controls not working.
