Window controls not working.
Currently the window controls only work on the door they are on except the passenger rear that doesn't work at all. The drivers door controls as well. The mirror controls work so I don't know if I have a switch issue or a wiring/connector issue?
The drivers controls what as well. Just itself? The master has both it's and the other doors on a common ground. It is a redundant ground so it is possible one will work and not the other. The most likely fix would be to replace the master. The passenger rear may have it's own issues.
You don’t need to pull the door panels for the 2009 and up LS/ LT
read this thread., post #5 and on
https://www.chevyhhr.net/forums/how-...ontacts-62119/
