Window Defrost
Old 12-10-2006, 12:49 PM
Window Defrost
Anyone else have a problem with the front window defrosting completely from one side to the other? We received some snow the other day and then it warmed up and then snowed a little again. Window defrosted fine except about 2 inches on each side. Unfortunately the vents are centered and do not extend to the edges of the window.
HillsdaleHHR is offline
Old 12-10-2006, 06:50 PM
dnvachon's Avatar
I noticed a similar thing except on mine it doesn't defrost about 4 inches along the passenger side of the windshield. I expect "they" messed up on the design of the windshield defrost vents. They could have put a little bit more powerful blower motor in there as well... just my opinion.
dnvachon is offline
Old 12-22-2013, 03:20 PM
MidgetHurse-LT's Avatar
Since they didn't change the design, my 2008 LT has the same problem and on the highway (when I drive a little faster...) the snow hits, melts a little and freezes back up and really trashes the wipers with ice! Glad I'm moving south next month... this design is dangerous to me.
MidgetHurse-LT is offline
Old 12-22-2013, 03:45 PM
Been a while since anybody brought it up. Drive carefully.....
SS fan is offline
Old 12-22-2013, 03:46 PM
skyline26's Avatar
hmm thats weird..i have a 2008 and in Canada we know winter! my defrost works like a charm! and its incredibly fast...just today from our freezing rain storm, had about 3-4 inch thick ice on my whole car, defrost took like 2 mins and all crumbled off the windshield and was good to go
skyline26 is offline
Old 12-22-2013, 04:45 PM
Check and replace your cabin air filters, if they're plugged up with gunk, you'll have restricted airflow through the HVAC system.
843de is offline
Old 12-22-2013, 06:01 PM
Lucky's Avatar
X2. That's a good thought.
Lucky is offline
Old 12-22-2013, 11:20 PM
Good call on checking that often neglected cabin filter!!!
The defroster's primary task is to defrost the INSIDE of the windows, removing the moisture, and it aids in removing the outside ice when you first warm up the car.
The defroster is not designed to remove the ice on the outside while you are driving at highway speeds, and definitely not designed to keep the base of the windshield clear of ice - ie: where the hood hangs over the wiper cowling
whopper is offline
Old 12-23-2013, 09:46 AM
Fox Hat's Avatar
x3 or is that 4 ? on the Cabin filter.
Also very cold ambient air temps and high speed make the metal that much colder and through heat transfer to the glass the outer edges will be where the condensation will want to collect.
On a similar note
When I pick up the wifey I noticed the same when the doors get opened and wifey gets in the car on a cold day. It goes away in a short time.
Its all about the humidity of the air in the car and the outside temps
Fox Hat is offline
Old 10-11-2019, 05:34 PM
Tara V Kelly's Avatar
Defrost issues
I have a 2006 HHR and I’m noticing the bottom left and right and 2-4 inches don’t defrost either need a solution have you found one
Tara V Kelly is offline
Quick Reply: Window Defrost
