Window Switch Light Fuse
the little led above the console stopped working. I have a sun roof so it was easy to take it out. However, replacing it did not do make it work. I can't seem to find the fuse. I have looked at the manual, but there is not one listed for this led. Does anyone know what circuit it is on?
Thanks,
Thanks,
It's Fuse # 59 PARK LAMPS, See below diagrams:
I hope these Diagrams help! You may need to change the LED itself, it could be burnt out! It's a 5MM LED, No resistor needed, It's built into the Wire already! I have Red in mine!!! works very well, and it's not annoying! I have also tried BRIGHT WHITE, and BLUE, which are also fun!
