Windshield washer sprayer question
My wipers work front and back. the sprayer works in the back when I press the button.
But the front only works sometimes. I have enough fluid. Fuses seem to be ok. Any ideas on what's going on. I got an 07 lt automatic.
Check your nozzles on the front, use a pin to clean them out and see if you're back to spraying. Windshield washer fluid can leave crusty deposits as it evaporates over time and that'll block the spray nozzles.
Not trying to thread jack but I'm curious about something with my squirts and this is the first thread I've seen on the subject. For the back one, is it supposed to kind of just pour fluid straight down the window or is it actually supposed to spray/mist? Once again sorry to thread jack.
