Windshield Wiper Problems
Old 10-06-2010 | 11:08 PM
frentzjr's Avatar
I am having a problem with the single wipe and intermittent wipe positions on my 07 HHR. In either position, it take about 6-10 times of switching to that position before it finally decides to work. Once it starts to work, I have no problems with it working again that day. Has anyone had a similar problem and how was it fixed; also, would it be covered by the powertrain warranty (yeah right) because I have 51,000 mi.
Thanks,
Jason
Old 10-07-2010 | 06:42 AM
Lucky's Avatar
Yep I have the same problem with my 08. I am taking it to the dealer it is still under the 3/36. I beleve it needs a new switch. I will keep you posted.
Old 03-15-2011 | 09:26 AM
frentzjr's Avatar
bump, anyone have a new idea?
Old 03-15-2011 | 07:07 PM
Lucky's Avatar
Dealer installed a new wiper switch in mine 2 months have not had any more problems
Old 03-15-2011 | 07:36 PM
farmer52's Avatar
Mine will occasionally do a similar thing. When I put it in the pulse position sometimes the wipers will move up about an inch and then stop. Within a few seconds it will start working fine. Mine is out of warranty so I will just live with it.
Old 03-16-2011 | 11:53 PM
Marzipan's Avatar
Thanks,
Jason
Possible cause of switch failure is dirty contacting surfaces.
I had this problem on another vehicle where wipers and turn signals would refuse to respond immediately ... but after a while they would do their thing. Cold weather and a cold switch were a factor. After the vehicle and switch had warmed up there was no problem.
I assume that switch grease thickened with the cold and blocked electrical contact. I took the switch apart ... carefully .... and cleaned it.
Old 03-17-2011 | 02:33 AM
Another thing to consider is the wiper motor itself, they can develop a dead spot on the commutator and that will mimic a bad wiper switch. As you "bump" it with the switch eventually it will get to a point where it will run, but when you shut if off it can and will land again on the dead spot.
Old 03-19-2011 | 12:47 PM
vdill276's Avatar
vdill276
How much did that switch cost, and was it in the steering column?
Slider001
Maintenance and Upkeep
7
04-21-2015 08:00 AM
oldtom
12-07-2013 10:49 AM
bigjoe
01-21-2013 09:10 AM
twistrman
07-18-2008 10:22 PM
