Won't start after amp installed
Old 07-02-2006 | 07:40 PM
TX-HHR's Avatar
Originally Posted by HHR PNOY
good job in troubleshooting! Also gives peeps that own an LS useful info about their wiring as well.
It's all about the info
CH, I think the wiring diagrams must be for the LT, my LS only has two connectors on the back of the radio and they dont match up with what I saw on the diagrams. My front and back speakers are on different connectors. Must be an LS thing. The diagrams do show that the pink wire is for "radio on" which I assumed would be the same as a turn on lead for an amp. I guess Chevy and I have different ideas about what "radio on" means. That's what I get for not testing the wires before I make my connections. Live and learn.
Old 07-02-2006 | 07:45 PM
captain howdy's Avatar
They probably are for the LT, they are the only radio schematics that I know of. My remote turn on is pink. Well, it's blue to my amp but the factory wire I tapped is pink.
Old 07-04-2006 | 03:18 PM
TX-HHR's Avatar
UPDATE: After everything worked fine two days ago. My HHR sat all day yesterday (I'm a bad owner, I know ) But I jumped in today and it wouldn't start. I checked connections, couldn't find anything wrong. I tried to remote start, and it came on, but when I put my key in and turned it to the run position, the motor cut off. At the time I was using my spare key so I switched back to my usual key thinking they may have the passkey chip thing embeded in the key that may be screwed up, and it started. :surprised I tried again with the spare key and it stated. Has started by remote and key about a dozen times since. I dont think this had anything to do with the amp I installed. Any ideas about whats going on here? I dont want to end up stranded somewhere.
Old 07-04-2006 | 04:07 PM
courthousedeb's Avatar
The spare key you're talking about...was it made at the dealership and not a factory key? If that is the case, you may be experiencing the same thing I did when I used one the dealer made. I posted a comment on this in another thread but for the life of me I don't remember where...so here's what I posted.
Check your keys after you get them. Insert your key and turn to ignition for 10 seconds without starting the engine, then install the new key and turn it to the ign on for 10 seconds. This allows your computer to verify the key. This was suggested to keep the ign from locking up when you really need to use the spare key. The dealer told me that this may need to be done up to 10-12 times and then the key will work. After you check the key start the engine and let it run for 30 seconds or so to be sure it works and the engine does not shut down.
Old 07-04-2006 | 04:19 PM
TX-HHR's Avatar
Good question. I made sure to ask for two keys and remotes when I bought the car. I have no idea if the dealer made one of them. Anyone know if GM ships our cars with one or two keys?
Deb, did the new key cuase the security light on the dash to come on? It's amber and at the bottom left of the dash.
Old 07-04-2006 | 05:05 PM
New cars should always come with 2 keys from what I understand...they did when I had my last one in the 70's.
When the dealer went to get the manual, title and other paperwork from wherever they store that stuff, there was not a 2nd key, so they told me they were making a new one for me, which I promptly put away and never tried to use until one day when I misplaced the original key.
In answer to the other question about the security light...I did not notice one, but that doesn't mean it didn't come on. But then again...I was so mad my new car wouldn't start, I probably wouldn't have seen it anyway.
Old 07-04-2006 | 09:01 PM
TX-HHR's Avatar
I know what you mean...
Old 07-05-2006 | 08:03 PM
TX-HHR's Avatar
Deb, Your key explaination makes alot of sense. When I work in the garage I take my spare key so when I set it down somewhere and lose it I haven't lost my regular key ring with house and work keys. I think there must also be some relation to the battery being disconnected too. I was making changes to my wiring and testing the car every few minutes until it started. It must have eventuly recognized the key. I guess the real problem is I've never had a car before that was smart enough to know which key was being turned. The stuff I stated about the pink wire not being the amp turn on lead was prob. not good information.
turtizzle222
06-22-2014 04:22 PM
knelson1969
09-05-2012 04:02 AM
donlow
07-20-2010 06:19 PM
HillsdaleHHR
02-21-2009 02:26 PM
Ratzilla
2.4L Performance Tech
11
06-13-2008 02:26 PM
Quick Reply: Won't start after amp installed
