Won't start after rinsing eng compartment.
Hey good evening guys, Whooper you hit it on the head, thank you kindly Sir. To all others my apologies for the lack of clarification, " donbrew " and "Whopper" you guys are awesome, after following your advice it finally started and stayed running yesterday but as luck would have it the eng light popped on & thru a (P0107) code popped up. Oh well... It's running at least. Thanks again guys and of course any advice is welcomed.
Good stuff.
Ok - P0107 = Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage, which points to the MAP sensor. It's located at the front of the engine, just above the throttle body - and is in a rather snug spot (and probably a good spot to collect water/moisture).
Here is a link to a thread about replacing/inspecting it: https://www.chevyhhr.net/forums/how-...acement-49757/
The writer said it was $116 at his dealer, but I think I paid about $60 or so at Autozone. I picked up the part, but haven't replaced it yet as the code was a one-time hit for me.
Try unplugging it, and hit the insides of the plugs with WD40 (I swear by that stuff - can't you tell?). Or, give it another day or two and see if it too dries out.
do keep us posted - this was an interesting one (I am easily amused :)....)
for the solution to the P0107 code - see https://www.chevyhhr.net/forums/prob...olution-50958/
