Wooly Worm?/New member
Old 08-05-2013, 10:23 PM
crawley595's Avatar
Question Wooly Worm?/New member
Hi im new to the forums and would like to know how to repair my air intake duct known as the wooly worm. Mine is torn apart and I do not want to spend $80 to replace it.
Is there a cheaper fix? Could i go to home depot and make me one? Any advice would be great thx!!!!
crawley595 is offline
Old 08-05-2013, 10:52 PM
Welcome-
Can U tape it ? Or hit the junk yard & snag a used one..
sleeper is offline
Old 08-05-2013, 11:35 PM
to the forum!
The GM part number is 15865168, list price is $77.12.
These folks have them for $47.20 +Frt.
http://www.gmpartsdirect.com/results...umber=15865168
You might also check at RockAuto, or give reparing it a shot with duct tape or Gorilla tape.
843de is offline
Old 08-06-2013, 09:56 AM
Isn't this about the third time someone has introduced themselves with "wooly worm" this year?
Cheapest way is get some mylar duct tape, not DUCK tape and wrap the coils. Never use a pressure washer under the hood of these cars next you will be noticing the firewall insulation has disappeared. Even chemicals and a hose will tear the paper felt to shreds.
donbrew is offline
Old 08-06-2013, 02:50 PM
db/sb's Avatar
I had the vehicle for 7 1/2 years and never referred to the intake duct as that........
db/sb is offline
Old 01-30-2021, 04:21 PM
infotek's Avatar
Exact fit kit
I fixed mine today with a perfect replacement lit from Spectre Performance at Oreillys. Web site said $20 but when they rang it up it was only $18!! I used the original clamp for one end and the other end went into the car snug. Awesome!
https://www.oreillyauto.com/detail/b...air+duct&pos=0
infotek is offline
Old 01-30-2021, 05:46 PM
You did it!! Awesome, did you notice this is a 2013 thread, many many threads about the worm!
Oldblue is offline
Old 01-31-2021, 10:25 AM
tiapetra's Avatar
Glad this old thread was updated with new info.
I might have a look ar the Sprectre tube at O'Reilly's
Taped my ripped one with A/C alum foil tape, works pretty well.
tiapetra is offline
Old 01-31-2021, 12:35 PM
I’m waiting till spring, I have some dryer tubing left over from the dual air intake set up I did on Oldblue.
This tubing, but I’ll put it on the OEM intake side
Like this , only neater not kinked or twisted
Oldblue is offline
Old 01-31-2021, 04:56 PM
PulpFriction's Avatar
There’s a guy on the HHR Facebook pages who sells used ones pulled from yards for $50 on EBay.
I grabbed a used on at a yard for $2 and good thing, because mine tore about two weeks later. The used ones can be fragile. It didn’t tear, really; the adhesive holding the felt spiral let go. I’ll try to glue it after deciding on the best stuff. Maybe epoxy, maybe something else that will both flex and resist heat.
There are plastic aftermarket numbers but they are noisier - the fuzzy dampens the noise. If mine tore I would consider glue and high-temp to be a better option.
If mine tears again I’ll probably just lighten my wallet with the brand-new correct OEM part.
PulpFriction is offline
Quick Reply: Wooly Worm?/New member
