Worn Carpet Under Clutch Pedal
For those that have manual HHR's, has your carpet under the clutch pedal worn almost through? The bracket that comes off of the foot pad on the clutch has worn down my carpet. there is no nap left on the carpet. Let me know if you guys have seen this. Thanks.
Jeff
Jeff
Jeff
Jeff
GET AN AUTOMATIC
Not an issue with the auto HHR since there is no pedal there. But on my previous two cars (Malibus), the emergency brake pedal was located near where a clutch pedal would've been. Now that would have been a fun ride
As for the worn carpet...I had the same problem with my 89 and 98 Cavaliers that had standards.
You could always wrap foam rubber around your left foot to soften the impact on the carpet, but you will lose some of the pedal feel.
However I do think that wear and tear are going to be normal with HHR's just like all of the other regular cars out there.
My mother did the same thing when she move from a 3 on the column to an auto; she did her first panic stop in the auto and that clutch went to the floor in record speed! Both my brother and I about fell out of the car from laughing so hard. Even she chuckled.
As I think about it, when I went from an auto to a 5 on the floor; I gave my mom her first ride and I grab the gear shift lever to put my truck in reverse. She had a good laugh as the wipers started their dance across the windshield. ...and I chuckled as well.
New cars (trucks) can be embarrassing.
-JJ
