Turbo Diesel?
Turbo Diesel?
So I'm a little new to the custom car world and was wondering if anyone has any opinions on the idea of the 2.8L TurboDiesil from the Colorado in an hhr for its raw power and torque out put.
Basically looking for advice if nothing else.hoping for a beefy naturally aspirated 4 cylinder.
--edit--
Specs page for referenced engine: 2.8L inline4 TurboDiesil
--edit--
Even if that engine bolted up to the trans, that much torque would be too much for it.
You'd want to go for the engine/trans combo which is probably configured for rear wheel drive.
then there is the small task of swapping the entire electrical and engine management systems.
Short version: buy an SS.
one other option if you are up for some custom work, add a supercharger or turbo to your current engine.
Plus it's direct injection which would require modification to your fuel system. And aren't diesel (correct spelling) fuel tanks designed differently than gasoline tanks? Do lots, and I mean lots of research before even thinking about spending a dime on this pipe dream......
Many years ago my brother in law bought a Mazda RX 7. It originally had the Mazda twin rotor Wankel engine in it. After spending lots of money on the Wankel he decided to put a little 4 cylinder diesel from an Onan light plant in it.
It took a lot of work to get the clutch figured out but once it was finished it ran and worked pretty well for him. Of course back then gas was selling for around 36 cents a gallon and number one diesel was selling for around half that.
You did not need a stop watch when clocking it from 0 to 60. A calender was more in order for that task.
Ok, not really. It actually was much quicker than it had been with the Wankel but then again the Wankel had not worked quite right from the time he got the car.
The original fuel tank held the diesel just fine. He did have to add a return line from the pump but I'm pretty sure that was the only mod he made on that.
When all was said and done with that project he probably could have bought a whole 'nother car for less money but, it kept him out of the bars for a few months.
The original owner had already had the engine rebuilt or perhaps replaced at least twice under warrantee, when it failed again he sold it darn cheap.
More that likely an RX-7 then. Much sportier looking than the Mazda sedans. I had a 79 for a short while back in the 90s.
Could well be, its been a long time and my brother in law has been dead for 8 years so I cant ask him. I do know it was a pretty sporty looking car, looked fast just sitting still.
I've seen a few of the original RX-7 here where the owners have dropped a Chev 350 in them - that will perk them up a bit no doubt.
