09 hhr ss starter problems
I need help I just bought my 2nd hhr this is a 09 hhr ss dorve it 2 days and now the when you go to start it with key in start pos it will crank and not fire but seems to want to start when you let off of the key and go to run pos it keeps cranking no start has did this 3 times has been at the chevy dealer for 2 weeks now they have not had the car do it for them and cant find anthing I have been a ase master tech for 15 years but have not worked on cars for the last 15 years so im lost when it comes to the newer cars
To start with Welcome
1. the way the key works is: you turn it to start and immediately let go of it. The starter will crank until it starts or times out.
2. So it does start?
3. It is really a bad idea to use your email as a screen name. Send a PM to 843de (the admin) to change it.
I only did this 3 times - it will crank till you actually take the key out of the ignition. It will start after it sits for half hour or so. It won't time out -seems like it wants to start. And thanks for the user name thing
Last edited by whopper; 02-03-2016 at 09:33 PM. Reason: Broke post into sentences for ease of reading for us old guys. ;)
Welcome to the site, how old is the battery? It could be getting on and starting to exit stave left!
It could also be loose ground wires, you'll find the just down to the right of the oil filter cap, the other end goes to the rad cradle on the engine side behind the drivers head light
Strange! I think there is a relay involved, maybe needs replacing.
I'll try to look into the wiring.
I tried, but it turns out my old Mitchell won't run on Windows 10.
However, I put "hhr wiring diagram" into GoOgle and I got a page full of wiring diagrams.
WOW! check this link out. http://carwiringdiagram.net
Position 51.
Position 51.
