1st Problem with the Stage 1
Old 11-26-2011 | 09:33 AM
  #101
XtremeSS's Avatar
Yes. You pressurized all the piping and the manifold. Mabe you missed something?
Old 11-26-2011 | 10:44 AM
  #102
KissMy08SS's Avatar
ahhh....probably not. If I missed something....the gauge would have told me....the PSI would have dropped off...and I would have heard a leak I'm sure..
Old 11-26-2011 | 10:47 AM
  #103
20HHRSS08's Avatar
the cold side gets pressure on the test .. so i think you might be okay there. im still leanign towards the "tune" causing the issues
Old 11-26-2011 | 12:46 PM
  #104
ATLsilverSS's Avatar
in only a couple isolated cases the ecu or the bcm has been the culprit
Old 11-26-2011 | 01:33 PM
  #105
20HHRSS08's Avatar
well shawn has replaced a ton of parts already .. sensors, intercooler, upper intercooler pipe, bypass valve, oil catch can , etc .. nothing has fixed the issue ... i think its either a wiring issue with GMS1 or its just the tune's itself
Old 11-26-2011 | 02:25 PM
  #106
KissMy08SS's Avatar
To be honest....the tech at the dealer told me he thinks it's the PCM. BUT...even if it was....I cant get anything done about it (as far as warranty goes) because the CEL isn't coming on.....that's what is KILLING ME!!
Old 11-26-2011 | 03:21 PM
  #107
Originally Posted by KissMy08SS
Had all of the connectors soldiered today....
The GMS1 seems to run fine...but the Trifecta bounces around and flutters....doesn't really hold a "direct" lb. of boost. It'll go from 26 lbs...to 15 lbs...to 20 lbs...ect. Any idea's? Could it be the software?
i feel your pain. i had a problem with my turbo and they wouldn't fix it cause i had no cel. they told me to bring it in when the turbo goes. the turbo eventually siezed up, i brought it in and the turbo was replaced, and when i did and got the car back, drove it less than 200 miles and the engine blew. cost them a hell of a lot more in the long run. retail cost for both repairs was over almost 9k not including labor.
Old 11-26-2011 | 03:27 PM
  #108
KissMy08SS's Avatar
At this point...I hope the turbo goes, blows the engine...and blows the hood off the d*** thing....
Old 11-26-2011 | 04:16 PM
  #109
20HHRSS08's Avatar
if this happens , ill text you my address and ill take all donations for used parts , ill give them a good home
Old 11-26-2011 | 07:33 PM
  #110
yeah but the luck of all that happening is that it would all happen at 100,001 miles i had taken mine in at sixty some thousand and seventy some thousand for the turbo issues and was told to bring it in if the turbo goes out cause there is nothing they could do without a cel. i told them it was bull **** and with my luck it would happen just outside of warranty but they didn't care. i took it in at 92k with the siezed turbo bearings.
Quick Reply: 1st Problem with the Stage 1
