1st Problem with the Stage 1
#71
Everything has been soldiered and a bracket has been made so the lower sensor does not come in contact with the AC compressor. I tryed to move the wastegate rod....but I couldn't get it to move at all. The nuts are still in place. I checked the BPV as well, the diaphragm looks good...I'm going to go ahead and replace the spring with a dejon spring as well.
refer to post 13.......https://www.chevyhhr.net/forums/show...t=23231&page=2
#72
here is what i was referring to with the wastegate rod nuts.....post 152
https://www.chevyhhr.net/forums/show...=23231&page=16
#76
The only thing I haven't installed or done yet is the upper IC pipe....ZZP said they are getting powder coated right now and should be sent out next week. I guess it's possible the upper IC has a hairline crack or something huh?....I highly doubt it though....
#77
inspect the wires that run from the map sensors to see if they are damaged in any way or coming in contact with anything. from every stg 1 issue i have ever read about it is almost always something to do with the lower map sensor or wiring.
#78
I wish there were someway I could just get a whole new harness (not sure what it consists of) and get the plu-n-play adapter kit for the GMS1....that way....I could atleast rule out any type of wiring issue. (no connectors, soldiers)
