Boost loss?? Cant figure it out. HELP!!
My boost keeps shutting down when ever I go to pass someone. She will downshift and run to the top of the gear, then shut down. How do I fix this? What is causing it? Ugggg...
Last week I had a problem with my lower TMAP sensor/connectors/harness causing the check engine light to come on. The symptom I had was that the boost was not working and the car was running in a "limp" mode, no power to pass or accelerate but yet I was able to drive the 110 miles to get back home on the interstate going 80! The dealer scanned and wound up changing the lower pigtail harness, 4 connectors and the TMAP sensor that were installed almost a year ago as part of the Power Upgrade (Stage 1 mod) that was done. The car works great again now. May not be the same thing you are experiencing as you did not mention the check engine light. Mine is a 2010 5 spd. Yours sounds like it may be something else in your turbo control circuit, the dealer should be able to fix you up pretty quickly. Good luck.
Glad to see you back on the job!! you were missed. It is never good when the lunitics run the asylum.
