Brembo Caliper Mount Torque
Old 11-30-2016 | 01:27 PM
rnmodes's Avatar
Am installing new front Brake Performance Rotors and Pads on my 2010 HHR SS Brembo based on good feedback from this forum. Unfortunately, their tech support rep was unable to provide feedback on whether they recommend grease between shim and piston, and what the Brembo mount caliper torque setting is. They referred me to 'my mechanic'.
Most importantly I think is the caliper mount torque setting - anyone have it? Searched the forum but unable to find. TIA
Old 11-30-2016 | 02:04 PM
Front Brakes:
Caliper guide pin bolts - 25 lb ft or 34 N•m
Brake hose-to-brake caliper bolt to the brake caliper- 33 lb ft or 44 N•m
Application Specification--------------------------------------Metric-- English
Brake Caliper Bleeder Valve - Front (J41, JL9, JM4)-----11 N•m-- 97 lb in
Brake Caliper Bleeder Valve - Rear (JL9)------------------11 N•m-- 97 lb in
Brake Caliper Bracket Bolt - Front (J41, JM4)-------------115 N•m-- 85 lb ft
Brake Caliper Bracket Bolt - Front (JL9)-------------------130 N•m-- 96 lb ft
Brake Caliper Bracket Bolt - Rear (JL9)--------------------115 N•m-- 85 lb ft
Brake Caliper Guide Pin Bolt - Front (J41, JL9, JM4)-----35 N•m-- 26 lb ft
Brake Caliper Guide Pin Bolt - Rear (JL9)------------------35 N•m-- 26 lb ft
Brake Hose Fitting Bolt - Front and Rear------------------40 N•m-- 30 lb ft
( Look on your RPO list in the glove box to determine which spec to use)
Copied from: https://www.chevyhhr.net/forums/how-...e-items-54648/
Old 11-30-2016 | 02:07 PM
96 ft lb per
Old 11-30-2016 | 02:16 PM
Oldblue - do you have the breakdown handy for the RPO codes J42, JL9 and JM4 - ie: which model/years?
You know me, I just hate using the search tool.
Old 11-30-2016 | 02:28 PM
Just this
https://www.chevyhhr.net/forums/gene...o-codes-10645/
Old 11-30-2016 | 02:52 PM
Cool - I'll update the Torque Value thread. Thanks.
Old 11-30-2016 | 03:10 PM
The Brembo package is RPO J56(not listed on the torque spec page). After searching over at CSS forums, it looks like the recommendations are 96 lbs. ft.(same as RPO JL9).
Old 11-30-2016 | 03:59 PM
I have heard people profess the use of both grease and glue between the pistons and the shims. Personally I have never seen a difference, so I leave them dry like the factory.
imagepower
12
10-30-2015 08:50 PM
carsrmilife
08-14-2014 04:11 PM
TomR00
Maintenance and Upkeep
07-19-2008 01:01 PM
