CEL on way to work today, OnStar says code P2261
If you had critters "hanging out" in your engine bay, I would scan all the wires to make sure someone wasn't "taste-testing the candy coated wires" under your hood.
I've been having unusual boost readings since I changed back to the stock cbv spring and the CEL went away. The turbo won't produce more than 9.5-ish lbs. of boost in any gear (almost to WOT). I'm pretty sure I've seen WELL over 10 lbs. of boost before. I did a search and I'm still not quite sure what normal boost levels are.
Even though the CEL went away on its own after the spring swap, does b.o.b. still need to be taken down to the dealer to have any codes cleared?
I have read on some threads here...(from another thread)
"bypass valve is stuck. Happens to me every now and then but never throws the code. I found that when it does that, just turn the car off, pop the hood and unplug the wiring harness that the bypass valve vacuum line connects to and you'll hear a click and the bypass valve releases. "
I too hear a click after I turn off the car in my garage. Is this the same "click"
Sorry to be so long but I like to be complete.
07azhhr
Fuel Economy - Hypermiling
12-29-2011 01:35 AM
crowbar
04-19-2006 04:39 PM
