Check Engine Light
Old 03-24-2016 | 08:32 PM
Klondike1776's Avatar
Check Engine Light
After starting the engine this morning, I noted the "Check Engine" light illuminated. After checking for a code, I saw it was for an "Air Mass Sensor" problem... I'm a newbie to the HHR SS and this engine, is that a common issue? Blow it out? Replace it? Or???? Thanks!
Old 03-24-2016 | 08:48 PM
Did you recently change the air filter and forget to plug the MassAirFlow sensor back in?
Old 03-24-2016 | 09:19 PM
If you want to ask about CEL codes, you should post up the actual number and not the generic description.
Fwiw. My code list doesn't show a "Air Mass Sensor" code. It does however show several codes labeled Mass Air Flow(MAF) Sensor.
Old 03-25-2016 | 11:59 AM
Thanks for your responses! NO, I did not recently change the air filter. However, I did some "small things," like checking the MAF connector and wiring, "jiggled" some of the black plastic tubing in and around the MAF Sensor, looked for some obvious air leaks, "jiggled" and moved some the "stuff" just a bit - including checked to see if the MAF Sensor electrical connector was loose, and pushed on it to be sure it was tightly connected. Then, reset the code that was displayed, started the engine, and the "Check Engine" light was extinguished - EUREKA! I have driven the car about 50 miles since and the "Check Engine" light has remained OFF.... Maybe it was "jiggling" and moving some of the "stuff" just a bit.... "Lucky," maybe - Keep watching for the "LIGHT" - you betcha... Thanks!!
Old 03-25-2016 | 12:16 PM
IF that fixed the problem the CEL would go off by itself, now ALL of the I/M testing will have to complete before you know if it's fixed. That can take 2 weeks.
It is bad policy to clear codes just because you can.
Old 03-25-2016 | 12:39 PM
Good info - thanks....
purple people eater
09-17-2016 01:07 PM
flooprigger
08-04-2013 08:58 AM
jmpnjoe86
03-10-2013 06:13 PM
menance
12-22-2010 06:14 PM
beachbum1970
03-25-2009 08:46 PM
Quick Reply: Check Engine Light
