Cooling fan module wire
https://www.mouser.com has the connectors and I presume also the pins, seals and cavity plugs. If you go that way or if you purchase the one from Ballenger, make sure you have access to the proper crimping tool as without that, it's likely the big contacts will die again..
Hi thank y'all for all the pointers y'all gave. I've been busy with work so I wasn't able to update on HHR on here but was able to read up quickly on what y'all said.
I was lucky enough to find a connector on Amazon that worked perfectly as a replacement. Found it by reading some of the Chevy SS forums since I saw the video on here showing they use the same connectors.
AITKEN Cooling Fan Control Module Connector Plug Wire Harness for Ford Edge/Lincoln MKX Ref #7T4Z-8B658-B, 941.0138.01. https://a.co/d/dYprJiE
This is the one I ended up buying on Amazon. Says it was used on Ford's and Lincoln's but it worked good as a replacement. Gonna keep an eye on it and will update on how well it's been holding up in the following week or so.
Again thank y'all for the help, it was much appreciated
IT20
09-22-2021 03:02 PM
hhrssz
01-22-2017 07:04 PM
antonalex
06-05-2009 06:24 PM
