Cracked oil pan trying to remove / Still cant remove!!!
Old 10-25-2024 | 11:50 AM
TurboKid1994's Avatar
After many hours trying to carefully pry the existing oil pan off ( After timing chain guide bolt broke and luckily didn't skip timing, but threw a bunch of crap in the pan)
I unfortunately started a crack near the timing cover side and eventually broke off a large hunk.
I threw caution to the wind and beat the ever-living heck out of the pan, breaking large chunks in the process.
The pan wiggles, but WILL NOT come loose. I can pry on said pan and it flexes like it wants to come off, but every tool i pry with eventually slips.
I can't see any other fasteners holding this pan in. I believe I had 17 bolts in all ( probably a few excess, near the starter)
Am I missing something holding this pan in?
2008 HHR SS
Old 10-25-2024 | 12:22 PM
Did you unbolt the dipstick tube ?
Old 10-25-2024 | 05:57 PM
I didn’t yet but it shouldn’t have that much holding power should it? Pan should have fallen down
Old 10-25-2024 | 06:17 PM
greg8453's Avatar
Might need to blast.
Old 10-25-2024 | 08:35 PM
Lonwane's Avatar
Gotta ask.
Are ALL of the bolts removed?
Old 10-25-2024 | 09:06 PM
There’s 18 bolts , 13 from the bottom and five on the transmission end
Old 10-28-2024 | 06:39 AM
Well…….. Did you get the oil pan off ?
Old 10-28-2024 | 07:29 AM
Hehehe yes the oil pan is off. My father was able to get it out. He says there was a bolt still in on the trans side but I’m positive I removed all specified bolts in that area.
new pan is on the way. Glad I decided to take the pan off though. Those bits would definitely block up the pick up tube filter
Old 10-28-2024 | 07:35 AM
I would advise you to replace the o-ring on the dipstick tube when you do the pan replacement. Don’t want any leaks.
Old 10-29-2024 | 05:43 AM
ok, thanks for the advice! Can I use some rings from a oring kit I’ve got? Are they specific?
Quick Reply: Cracked oil pan trying to remove / Still cant remove!!!
