Difference on Springs SS over the LT ??
Was there a difference on the SS Springs over the 2LT Springs???? Did the SS Springs make the truck lower than the Stock Springs on a LT ??I assume the SS Springs will fit in place on a LT Truck??
The SS springs have a higher spring rate and are about 3/4" lower than the LT2 springs.
If you drive your car[not truck] aggressive at times, then you might consider Pedders springs, front and rear. Pedders are the same spring rate a SS springs, and put the car into the best stance for a FWD car to handle properly. Quality cost a little more, but worth it, in the end.
In my books there are two ways for people to mod their cars. Find the cheapest parts and end up with a pooch, or spring for the good parts off the top. To put it again as I have said in a prior thread. "You want oats that has already been through the horse, or you want fresh oats". fresh oats work every time, and last. "Moon"
LT2 front Struts Differentr than SS???
Again-- Would you recomend me to replace the front struts and Springs with SS ones since I'm installing SS Springs on the rear?? Are the front struts & Springs different on the SS than my LT2 ones I currently have??
Yes the the ss got different "better" springs and struts than any other hhr. Moon I would usually agree with spend the money but I bought the ssi springs off eBay (120$) shipped been some pretty damn good springs so far and I would say that I put this poor thing through it's passes
The SS struts are better than the FE3 ones, as they were engineered to match the SS springs, but you may not even notice the difference. If you want the best, then go for it.
The difference is more noticeable when going from the base LS FE1 to the gas-charged FE3.
