Feels like turbo lag
Old 03-15-2012 | 08:49 PM
pitbull76's Avatar
OK today my SS started to act up. First I had no boost for a short trip. Upon restart, it has boost but it feels like it has serious turbo lag. From a standing start, it initially has low or no boost and feels weak, but then boost builds and it has good power for a bit. When moving, boost is similar. None at first and then it builds up. No CEL yet. Has anyone experienced anything like this?
Some specifics on my car: 08 SS, Stg 1. auto ~47K miles. I've had it since 5K miles so I know what I'm feeling is NOT normal. Thanks for any help!
Old 03-15-2012 | 08:55 PM
badassbowtie's Avatar
sounds like the bypass valve spring. but i'm not sure. someone else may be able to confirm
Old 03-15-2012 | 08:57 PM
Take a look at the bottom wires for the stg-1, sounds like they are frayed.
Old 03-15-2012 | 09:53 PM
pitbull76's Avatar
I did look and I can see I have minimal or no clearance with the lower TMAP, but would issues with that typically cause delayed turbo spool-up? Because it will still boost to 20+psi, but the boost is just delayed.
Old 03-15-2012 | 09:59 PM
Could be a number of things. First thought is a boost leak problem.Check upper and lower IC pipes and intercooler itself(haven't bumped any curbs with the front have you?) While your under there,check that lower Tmap wiring as stated above.
Old 03-16-2012 | 01:51 AM
IgottaWoody's Avatar
Lower map will generally make it fall flat on its face anytime the eng torques over...building up slow sounds like ..leak....slow spooling turbo...stuck spring or valve ... if you have no lower clearance take a zip tie and pull the lower tube forward until you get a real fix worked out..corner of radiator works good.
Old 03-16-2012 | 07:42 AM
pitbull76's Avatar
Thanks for your help. My recollection of reading about the lower TMAP issues was more like you list above. By stuck spring or valve, do you mean the BOV spring? That sounds like a good starting point, and after a bit of searching might also explain my temporary complete loss of boost on one trip. I'll also use your idea of the zip tie for clearance until I can get something better worked out.
Old 03-16-2012 | 09:33 AM
Tried to buy a forge from Genuine Saab they are still out of stock.
Old 03-22-2012 | 11:06 AM
pitbull76's Avatar
I ordered a new Forge BOV just yesterday. The funny think is the car really hasn't been running too badly for the last couple days, even though I've done nothing to it yet. Hopefully installing the Forge valve and fixing the clearance issue will resolve my problems permanantly. I'll let you guys know once I have the BOV in place.
Old 03-22-2012 | 11:42 AM
I installed the forge yesterday, the yellow spring works perfect with stg-1.
one of these have kept the bottom wiring from rubbing, kudo's to the Mr. Goodwrench who did it for me.
