Has anyone figured the problems with Stage 1?
Like most of you whom have the GMP Stage 1 upgrade, my car also suffers the complaints. The jerking, boost spiking, loss of boost, and codes for maf, maps, etc......I think it to either be a tuning issue or a map issue. My car ONLY acts up in high humidity, or hot temperatures. It was a PITA last summer/fall, resetting the computer daily to clear codes. Late fall through winter never once gave me an issue. This tells me it cannot be a connector issue, or it would do it all the time. In Louisiana it has warmed up to the 80's and humidity is high, it is acting up again. So has GM admitted to any faults with this system. I'm about to take it to the dealer and have it returned to stock.
Read on:
http://www.sandyblogs.com/cgi-bin/mt...gs=10&limit=20
Haven't pulled any looms apart to check. I bought it used about 8 months ago, ran fine for the 1st month, then started getting hot outside and problems began. Got cold outside, no problems, now getting hot again, and problems are coming back. I bought it as a DD for the gas mileage. Shelby gets 17-20, and the Lightning on a good day sees 15. But it really is a PITA, so I may trade it off. I've got a very good tech at a dealer where I used to work, I may give him a shot at figuring it out. If it's a MAF problem as that has been the most current code, is that coverered under the GM 5/100K? I'm at 42K miles currently so I'm out of 3/36.
