Heater core removal
Heater core removal
Hello I am in the middle of removing the heater core. I looked at the photo that's attached and it looks like there's 12 5.5 mm bolts that hold the cover in place.
I removed them and the plastic outlet that attaches to the floor tubes.
I unsnapped tree lock clips around the housing.
I removed one nut on engine side of the firewall.
I srill cannot get the plasic housing off even with moderate prying.
I did search this site first but didn't find anything so thought I would post the question.
What am i missing????
Thanks
Thanks
Thanks for the videos. Hopefully i dont have to remove whole dash.
I am following procedure on autozone step by step.
No 20 says use small chisel to remove heater core cover heat stakes.
What and whete are these?? No luck finding on internet search.
Has anyone replaced their heater core??
Thanks
Thanks
Has anyone removed their heater core? Still working on it.
So I'm still working on my heater core I've attached to pictures of where I'm at . when I try to pry the heater core cover I cannot get it to come loose near the firewall. I can get it about an inch wide Gap around the front and sides but the closer I get to the firewall it doesn't want to open up.
To I need to remove all of that metal framing?. It's not like the 2008 Cobalt that's in the video. That - metal framing is different.
So if you've actually removed one any help would be appreciated on how to get that cover off.
To top it off second week in third world california working in dark with flashlight and no electricity...
Thanks Donbrew.
I have both nuts off of # 1and 2 im image. I did not take nut off a/c block. In the Chilton manual i didn't see that nut removed.
I did read about removing the firewall stud. The only one that happened to turn was #1 in your diagram. Regrettably it just spins and does not unscrew.....
What type of manual are you using? I liked that it has links.
Thanks again for taking time to reply
Thanks Donbrew.
Heater core
Ok finally got it out and replaced.
For Nick 93 and anyone else interested here are some pictures and info.
First on the firewall there is one stud under a plastic clip holder that holds a metal tube. You need to unclip rhen remove tube then pull plastic clip off and there is another stud. Take 10mm nut off. I think a 4.5mm fit end and unscrew. It will come loose but still remains in firewall. You can only remove from inside drivers side .
Next make sure you removed the one silver bolt to the rightside of radio.very hard to get to.
Also there is about a three inch tube that goes through firewall. It is to the left of turbo. This needs to come out from inside and is attached to the heater core cover. See pictures.
I pryed hard down on then pulled forward and downward until i cleared the drain tube.
I did make a crack in cover and broke several tabs. However there are more than enough bolts and i used silicone on crack.
The heater core is easy once cover is off.
When reinstalling you have to do that firewall studs early on to get it to align right.
I found i needed to jack right corner of steel frame when i put everything back together
