Heater core removal
Main dash removal
Thanks Donbrew.
I have both nuts off of # 1and 2 im image. I did not take nut off a/c block. In the Chilton manual i didn't see that nut removed.
I did read about removing the firewall stud. The only one that happened to turn was #1 in your diagram. Regrettably it just spins and does not unscrew.....
What type of manual are you using? I liked that it has links.
Thanks again for taking time to reply
just saw your pictures posted of the main dash removed. How did you get the 3 screws removed that are screwed in from the inside of the dash?
