Help!! No boost!!
Old 12-01-2012, 01:32 PM
Nazgul 9
Guest
Posts: n/a
Unhappy Help!! No boost!!
Hello all.... I am hoping someone here can help.. a couple of months ago my check engine light came on and I lost all my boost power if i stepped on the gas it would go to 0 and no further...I took it to my shop and the guy check the codes and it was showing bad MAF sensor I did not have the money at the time so he reset the codes and it was actually fine. about 3 weeks ago I took a rather long trip (((over400 miles))) and on the way back I lost boost... I called him about it and brought it in he checked the codes and sure enough its the MAF sensor..
I had him replace it finally yesterday and all day yesterday it was fine I went out this Morning and ... no boost I am so at a loss here and I can't get it back to him till Monday does anyone have any idea what may be going on here..?
O I should say that when the boost goes you can hear a change in the airflow meaning the sound my car makes.. could be by chance be the BOV?
Thanks for any help you can give...
Old 12-01-2012, 02:01 PM
badassbowtie's Avatar
have the code read before someone rips you off(unless its too late)...do you have an aftermarket intake or new filter?
P0101 is a common code because the MAF sensor hates everything but a stock paper filter. the code is a circulation/volume problem that the computer doesn't like.
I learned this the hard way with a custom short ram I made that sounded amazing, but now sits in my garage. You have to get tuned for the extra air with a new filter/anything aftermarket(if thats what you have)
EDIT: Is your K&N new?
badassbowtie is offline
Old 12-01-2012, 02:17 PM
Nazgul 9
Guest
Posts: n/a
I have had the K&N for awhile one of the first mods I got .. could it take awhile for this to be an issue?
Old 12-01-2012, 02:24 PM
Nazgul 9
Guest
Posts: n/a
So it I take it back to the guy who did the Trifecta tune he can fix this? if that is what the problem is....?
Old 12-01-2012, 03:37 PM
XtremeSS's Avatar
MAF codes are also an indication of a boost leak. You may have a loose coupler, cracked charge pipe, cracked intercooler, bad BPV, or leaking vac lines.
XtremeSS is offline
Old 12-01-2012, 03:41 PM
Nazgul 9
Guest
Posts: n/a
O man that sounds VERY expensive .....
Old 12-01-2012, 03:44 PM
XtremeSS's Avatar
Do you know how to do a boost leak test?
XtremeSS is offline
Old 12-01-2012, 03:57 PM
Nazgul 9
Guest
Posts: n/a
No I do not.... or how to check any of the other things you talked about.. Thank you so much for your help this has been driving me nuts...
XtremeSS's Avatar
Here is a link on how to do a boost leak test.
http://www.cobaltss.net/forums/how-g...ss-lnf-223319/
The only thing you cant test with this method is the BPV.
XtremeSS is offline
Old 12-01-2012, 04:10 PM
Nazgul 9
Guest
Posts: n/a
Thank you :)
foxtrotraptor
45
08-10-2013 06:00 AM
redss87
04-17-2013 02:42 PM
ssdivin
04-26-2011 06:55 PM
JJ's BLACK SS
07-22-2008 10:32 AM
ecopower02
2.2L Performance Tech
27
08-14-2006 09:09 AM
Quick Reply: Help!! No boost!!
