HHR SS air box mounts
Old 07-27-2023, 08:02 PM
Sonshineclg's Avatar
Looking HHR SS air box mounting insulators/grommets or part numbers. There are two in the front (cracked) and one in the rear (gone).
Sonshineclg is offline
Old 07-27-2023, 08:48 PM
From the "common part number " forum.
Air Filter Box mounting Grommet - GM calls it an "Insulator"
- P/N - 12563914 (2.2L/2.4L)
- P/N - 25920906 (2.0L)
RJ_RS_SS_350 is offline
Old 07-30-2023, 09:35 AM
SmittyBlackstone's Avatar
Do you have the part number for the clips for the 2.0?
SmittyBlackstone is offline
Old 07-30-2023, 10:15 AM
I bet a GM parts department would have all of the part numbers.
donbrew is offline
Old 07-30-2023, 01:36 PM
Thanks all. I Mcgivered it with grommets and o-rings. No more wobble.
Old 07-30-2023, 02:25 PM
GM P/N 03817880 No longer available.
You could try Google, Amazon, eBay.
I don't use the clips, really not necessary.
Old 01-06-2024, 08:52 PM
hhrumadbruh's Avatar
Here's my fix
hhrumadbruh is offline
Old 03-21-2024, 02:42 PM
felcan's Avatar
where did you get that stud replacement
felcan is offline
Old 03-21-2024, 03:27 PM
McGiver usually at a hardware store or farm store.
Oldblue is offline
Old 04-05-2024, 12:16 AM
These were at my local ace labeled as "automotive stud" smaller side fits our valve covers, bigger side is something else.
Amazon Amazon
Google search "automotive stud" comes up with a bunch of results. Just make sure at least one side has the right thread pitch and size (the one I linked was a 5 pack of the 3/8-16 - can't remember what size we need for the 2.0)
Quick Reply: HHR SS air box mounts
