Hhr/ss cv axles
Hhr/ss cv axles
Has anyone had any issues with theres as of yet? I'm talking to the Drive Shaft Shop out of Salisbury,North Carolina. They are expensive but with the new setup we are planning for the Gadget over @ Secret Services, I'm thinking I'm going to need them
Hes trying to tell you power MAKES speed...stock axles held up at athe drags with over 350 HP..base it on that..also are you ever using slicks? If not then run with what ya got cause the stocks tires will turn before the axles snap....
The chief factor determining torque shock to the drivetrain is traction, not power. 95% of the time with FWD, the tires are the safety fuse for the drivetrain. Even at 250 HP, put some slicks on there and watch clutch, trans, and halfshafts start breaking. I've seen some fairly shabby work come out of the Driveshaft Shop.
