Intercooler - stupid newbie question
Am I correct that the intercooler is a liquid system...antifreeze and water? Is it a separate system from the engine cooling system?
If so, has anyone tried to lower IC temps by using a "water-wetter" product?
Jim
Jim
negative...ours is an air to air system. you could lower your engine temps with water wetter. if you want to lower your ic temps, upgrade the ic
