limited slip
Worth it
If you have an SS manual, then not having the LSD with all that power would be missed. Conventional disc brakes will probably stop you just as fast as Brembos (plus there's no easy conversion path), but the handling issues with no LSD are significant - and fixable.
Mine was making that suspension squeek/schrunch noise when we were in the great white north -18F got ahold of the dealer in Edmonton they say it is needing lube at those bushings sounded fishy to me but it stopped doing it so driving 2000 miles in the cold must have worked them in haven't heard it since.
