No Boost
No Boost
Hello all,
Just drove home about 10 miles with no boost. There is no CEL. This is the first time this has happened. I don't think it has the GM upgrade. When i bought the car with 64k it ran awesome had about 15-17 psi. Never more never less. A few months ago it started a faint crackling sound and around the same time i lost a couple psi. the past few months i've had 13-14 psi give or take along with a random hesitation. A week ago i had a CEL p0101. I had the MAF replaced. Not sure if any of this is related to the current no boost issue but i'm throwing out the history of the car just in case it helps anyone help me. Ive had the car about a year and it has 86k on it. Ive read many threads on here with the same no boost issue but those cars were GM upgrade cars. I'm stuck. Any help would be greatly appreciated!!
I've inspected everything i could. Car on stands looked underneath. The only thing i saw that confused me was a little oil on the bottom side of the inlet pipe right before the turbo. Not sure what that's all about. Connections appeared to be ok.
I did the best visual inspection of the piping i could with the engine running and not running. Did not see any obvious leaks. I found the boost leak test thread on here. It's -10 degrees here now so I might take it to my mechanic for the leak test.
If you can't see a visible leak area, you might want to take a look at the BPV on the turbo. Look for a bad diaphram.
Pain in the rear to take out for a look but it could save you some diagnostic time if it turns up bad.
Here's a stock "good" one.
Attachment 15710
Attachment 15710
I have an appointment for Friday @ 1400 to get the BPV checked out. I'm having them do general inspection of the piping and whatnot as well. Anything else I should have them check while they are in there? I hate taking my car to the shop but it's just too damn cold outside for me to justify doing it myself. (no garage)
