No start after engine wiring replacement.
Just replaced my engine harness do to a bad connection at the pcm and now I am not getting anything when I try to turn the car over. I have checked the connections 3 times now and they are all hooked up and tight. Any help would be appreciated!
make sure when u screwed the fuse block bolts that pull the connectors in that u pulled them in all the way u think u did but they will keep going it will give u a no start they have to click and stop turning good luck iv done it so hope thats all it is , iv also had a problem when i change a harness that it did not have a pink wire in it and it would not start even tho they were the same year just my thoughts
Definitely ready to drive the **** out of her. Been dealing with this electrical issue since I bought her back in Jan of 19. Can't wait to be able to go places without worrying about where it's gonna break down at.
mastersanka2020
10-10-2016 09:13 AM
chevhhrdummy
09-30-2014 07:48 PM
