oil leak
Skyline: Why the picture of an automatic trans when the OP clearly stated he has a standard transmission ???
No need to confuse things.
The link you posted might help but it is for the non SS 5 speed transmission.
FYI:The SS 5 speed trans.(MU3) only holds 2 qts of fluid. It does NOT use automatic trans. fluid like the regular HHR 5 speeds do.
Per the owners manual: Manual
Transmission
(2.0L L4
engine)
Manual Transmission Fluid
(GM Part No. U.S. 88862472,
in Canada 88862473).
Transmission
(2.0L L4
engine)
The oil leak is pretty unlikely to be coming from the transmission itself unless maintenance was recently done on it. The leak is far more likely to be hydraulic fluid from the clutch slave cylinder or an engine main seal. Might be useful to post some photos of your leak.
