Output speed sensor
Input speed sensor
Hi. New here. Have owned my 2008 HHR SS since new. Input speed sensor. Is this an easy thing to replace? I already purchased the part. From the drawing I have found, it appears to be right under the transmission cover. Is that correct? My mechanic (not the dealer) is concerned because he doesn't do transmission work.. but from what I see, it is just remove cover, replace sensor, put cover back on. Correct or am I thinking wrong? Thanks for your help.
