P0101 question...I know, not another one
Old 01-30-2013 | 11:27 AM
  #31
IgottaWoody's Avatar
Ive got 60k on my filter and its still clean...tap it out now and then..still has plenty a daylight shining thru..unusual. yeah..its stock....the routing of the intake and the fact it draws air from inside the fender eliminates alot of dirt you would normally pick up. Airbox is clean too..just painted it not too long ago..
Old 02-06-2013 | 06:36 PM
  #32
badassbowtie's Avatar
So I have done a ton of reading on this pesky air filter thing. From what I gather, the basic problem is the air entering the intake will swirl when conditions are right. I have also read that the "honeycomb" will correct this sometimes. What I did today was compare the stock paper filter with my K & N replacement filter.
The difference (visually) is the metal mesh around the paper compared to the K & N which doesn't have this pattern.
Enter Brain:
I have this stupid idea, I am going to try to re create the same airflow pattern with some gutter guard. If it works, then I am a genius, If not then you all can call me what ever names you feel the need to
It is too dark to take a picture, but I will update my post again tomorrow with my results and a picture if successful
JB Toronto SS
11-21-2017 09:08 PM
BLUEHHRSS5SPEED
41
05-13-2016 06:12 PM
Mike Yeager
04-04-2013 10:22 PM
bartSS
0
09-08-2010 02:21 PM
JB Toronto SS
06-24-2010 07:56 AM
Quick Reply: P0101 question...I know, not another one
