Pending CEL P2187 Code
Old 08-19-2013 | 08:49 PM
curyfed's Avatar
Hi guys,
I hate to make my first post an issue with my car, unfortunately, those are the cards I was dealt. Anyways. So I have been getting this P2187 code. It doesn't trip the CEL but it does limit my boost and throttle response. When the ecm reads this trouble code I can't go above 10-12 psi. I have a ZZP catless downpipe, k&n intake and just recently have had the gms1 done. I didn't have any issues prior to the stage kit. I've been having this issue since I did the stage kit. I double checked the seals on the kit and made sure everything is solid. I'm not finding anything there. I can usually reset it with my code scanner and the car will run for about a day and then go back into its limp mode. I'm at a loss. I checked the intake to make sure it wasn't that and it wasn't. The catless downpipe and intake I had on the car for a week before putting the stage kit on. I was considering calling the dealership to see maybe there was something wrong with the tune. Hope someone can help. Thanks.
Inder
Old 08-19-2013 | 10:36 PM
P2187 - System Too Lean at Idle Bank 1
The SS guys will weigh in here soon I'm sure, but the first two things that came to mind are that maybe the ECM needs reflashed, or your MAF may be faulty or need cleaned.
Give our "Search" function a try, and to the forum!
Old 08-20-2013 | 06:35 AM
curyfed's Avatar
Thanks for the search function idea. I have already tried that and not many threads had a resolution.
Old 08-20-2013 | 06:55 AM
If you're running a catless DP, then you may have to get a tune for it. The turbo upgrade or Stage 1 kit is designed around a stock setup. Running the mods you are, sounds like it may be time for a tune.
One of our site SS experts can probably tell you more.
Old 08-20-2013 | 08:51 AM
Consider looking at the flex pipe for a hole.
Old 08-20-2013 | 09:27 AM
curyfed's Avatar
Thanks guys. I'll look into both of those avenues
BLUEHHRSS5SPEED
41
05-13-2016 06:12 PM
working on it
Maintenance and Upkeep
11-24-2014 06:27 AM
asanti
06-27-2014 05:18 PM
BlackknighT
North East
01-31-2011 07:18 PM
SindyDix
08-27-2006 12:50 PM
Quick Reply: Pending CEL P2187 Code
