Revs up by itself between shifts?
#102
Huh. Thread opened 4/15/2008. A definitive solution 99 posts and over 16 years later. Gotta be a new record.
So, it seems this issue can be caused by a weak or broken clutch pedal return spring, and/or a sticky mechanism. In any event, the pedal wasn’t fully retracting when released. So simple!
This seems a good place to point out that the spring is discontinued, but a couple of Corvette springs work, maybe a little stiffer, and cheaper. C5? C6? I don’t remember which one(s). Was discussed a couple times in these forums, though.
