Time for new front brake pads. Where to go?
Your opinion.
I have used both and have my own opinion.
First off the rotor issue is not a warp there are other factors that cause the pulse. Read the threads on Rotor thickness variation including the The service bulletins on it. Also read the The proper way to seat and bed the pads to prevent the pad material from sticking to the rotors.
The reason many never fix their issue is they are not addressing the real problem.
Calipers already float so even if a rotor was warped it would move with rotor.
http://en.tarox.com/
Tarox Brake Conversion Kit with 6 Pot Calipers and 305x28mm Discs (Fiat 500 Abarth)
Improved braking performance and stylish look for Fiat 500 Abarth
Tarox, Italy is a worldwide leader in the engineering, development and production of braking systems and components for fast road and racing cars. For those seeking to improve upon the standard factory braking system, the Tarox Brake Conversion Kit is the answer.
The company is one of the few manufacturers in the world to offer a six-pot caliper for road and track day use. Thanks to the various adapting mounting brackets the Tarox caliper can be installed on the car without any modifications thus allowing the use much better discs than the original ones.
Although the new Tarox 6-pot caliper system was originally designed for competition use it also delivered surprising performances and smooth braking when used on everyday road use vehicles.
Your benefits:
• Reduced stopping distance
• Higher temperature tolerance
• High carbon cast iron metallurgy on discs insures peak performance, noise reduction and improved comfort
• More evenly distributed pressure on the pads
• Better cooling action of the pads, because of more airflow behind the pad's metal support
• Less stress factor on the caliper itself
• More clamping action resulting in more braking power due to the presence of more pistons
• Excellent resistance to fade
• Automatic brake pad de-glazing
• Tarox discs are among the only ones with real heat treatment for strength.
Fitting a Tarox upgrade kit will give you amazing braking performance and total confidence. By matching six piston calipers to the discs, problems such as disc failure, deformation and vibration are eliminated. The diameters of the pistons in the calipers are specific to each application to take into account your car's master cylinder.
All this included in the kit:
• 2 Tarox six pistons light weight calipers made from solid alloy billet
• 2 Tarox 305x28mm brake discs
• 2 Tarox adaptor clamps
• 1 set of Tarox brake pads
• 1 set of Tarox brake hoses
Disc options
The conversion kit is available with the spiral grooved F2000 discs as standard or with Sport Japan Plus or D95 discs as an option. See detailed images below when ordering your preferred design. Tick the box "Choose Disc Design" before you "Add to Cart".
Choose one of the three following models:
1) F2000 Spiral Grooved as standard
2) Sport Japan Drilled and Grooved design
3) D95 Cross Drilled design
Minimum 17" wheels required for this Brake System. Disc size 305x28mm. All Tarox calipers come with light grey hard Caliper Color (450 Wickers) anodizing for maximum life.
Online discount and delivery
Already a customer? Sign in to get the total price including shipping. First-time visitors - please sign in and create your free account.
Availability: Special order only. Please contact us for delivery time before ordering. 0%
Details
SKU 511541
Weight 25.00 kg
Manufacturer Code KMFI0900
List price: £ 999.00
Online Price: £ 1,168.00
ferodo is used in high end cars
also check carbotek and pagid
Not the first company to fudge the truth a little.
Ferodo pads are off all quality including lower end cars like the HHR. Often when brakes like Ferodo and Brembo become more common on the common cars the quality is not the same as you will get on a Enzo or ZR1.
Often on these lower end kits the parts may be better than the off the shelf parts but they are not the same quality as the high end cars.
The HHR as Sachs struts too but they are not the same grade as the higher end cars either. There are price guides OE suppliers have to meet and they comprimise much to make a profit. Just check out most OE tires and you will find they are often older models that the companies sell at little profit. The only cars to get top line tires are the high end models or cars like the Volt or Prius that need special tires for more range.
I work in the industry and have my own opinion just as you have yours.
I sell some brakes systems that make claims that I know are not fully true and I will not lie for them. Not all performance parts are honest. Just look at the Tornado.
Charvel1975
Maintenance and Upkeep
06-23-2013 04:38 PM
