turbo issues help please
Old 02-24-2010 | 08:15 PM
JJ's BLACK SS's Avatar
i am having some issues with boost i have the gm stage kit and i am getting variations on boost pressure some times i can punch it and it will go to 14psi and let off the throttle a couple of times and it will go to 23psi like normal i have no codes.
Old 02-24-2010 | 09:27 PM
HHRSSouth's Avatar
If its not due extreme changes in temperature, it almost sounds to me like your diaphragm is collapsing your stock BPV spring and its getting stuck. I had a similar issue and found mine collapsed at 600 miles on the OD, put a new dejon spring in and fixed.
Not guaranteeing this is the issue, just sounds similar and the Dejon spring is like $10. You could try that or take it to the dealer.
Old 02-24-2010 | 09:34 PM
i have that on the other hhr i may pull it out and try it the motor and turbo only has 500 miles on them
Old 02-24-2010 | 09:39 PM
HHRSSouth's Avatar
I would, 30 minute change out max, might save you a trip to the dealership.
Old 02-25-2010 | 08:24 AM
JeramieJJ's Avatar
I have had two stock turbos with the stock BOV.......everytime I pop out the BOV, it is swallowed by the diaphragm. Similiar issues observed in boost as your describing. Dejon spring resolved everytime.
v-twins
2.0L Performance Tech
71
11-07-2016 09:04 AM
LuckyLadySD
06-12-2014 02:09 AM
JeramieJJ
06-28-2010 08:01 PM
TurboTechRacing
0
10-28-2009 09:03 PM
Quick Reply: turbo issues help please
