What symptoms does the carbon build up cause?
Old 03-10-2021 | 08:13 PM
SS Performance's Avatar
I recently purchased a 08 SS with 99K miles. The motor seems a little rough at idle. I'm not sure if this is normal since this is the first 4cyl I have owned.
Car seems to drive OK and I'm averaging about 26 mpg on my work commute, 35 miles each way mostly highway.
I also have a ticking noise that seems to come from the front drivers side of the engine. On start up it's about 4 or 5 per second then after about a minute it drops to about 1 per second at idle. It does change with RPM. I don't hear it in the car only with the hood open.
Any insight would be appreciated.
Old 03-10-2021 | 08:39 PM
The ticking is likely the mechanical fuel pump, normal.
Carbon build up on the intake valves will eventually cause loss of compression and misfires.
Old 03-11-2021 | 08:35 AM
Rough idle could be spark plugs, at your mileage they are due for replacement AC Delco Iridium 41-108 , do not try to gap them, that little whisker can break off.
Old 03-11-2021 | 05:28 PM
Rough idle could be something dragging down the idle speed. AC compressor or tensioner.
Old 03-11-2021 | 08:35 PM
A loose timing chain can cause rough idle!
Old 03-11-2021 | 08:40 PM
Or even a dirty air filter. I chased a P0101 for a little while, new filter fixed it. But it ran good until the code was set or even pending.
Old 03-13-2021 | 03:50 PM
Thank you for all the feedback.
I replaced the air cleaner last weekend and today I SeaFoamed the engine and then replaced the spark plugs and coils.
She seems to run a bit smoother now and I also noticed she's idling a bit higher before about 700 rpm now about 900,
I'll see how she runs this week. Hopefully all is well now
Thanks
Craig
Old 03-13-2021 | 05:30 PM
Hope, I’d take the valve cover off to be sure the timing chain wasn’t stretched , they last 80,000 to 150,000 miles with proper maintenance, but the front guide can give out earlier then that, the upper bolt gets chewed up and spit out.
Even slack like this is enough to bust up the front guide and cause it to idle rough.
RBodeman
02-28-2012 07:49 PM
battoo
07-16-2011 12:16 AM
ImNewHere
01-06-2011 02:20 AM
Mackey14
10-07-2010 05:42 PM
Sunflowerhippi
06-14-2010 12:09 PM
