Turbo Tech Racing Releases Rear Sway Bar
#391
just ordered a bar in black.....cant wait. ....question, there's a solid round "bar" up inside the V-beam rear "axle".......what is that bar all about...is it there just to provide a more rigid axle or is it a sway bar, as well ??....and, does the TTR 1" bar make contact with the V-beam axle..??
#392
THat is the factory torsion/sway bar, it stays installed in there, dont remove it. Our bar is a "addition" to that.
When you get it, our bar will also go up in the "V" for maximum clearance. It does not cotact the "V" of the rear axle beam.
#394
Turbo Tech Sway Bar
I ordered a red one, I received it a few days back and installed it today. Great fit. Nice packaging and instructions. Quick shipment. Excellent communication with vendor. (But I am still waiting to get the decals).
The instuctions says to use a 15MM socket to bolt it on. Mine came with 17MM bolts.
#396
Sway bar
Driving in a straight line, no difference.
But now I can push the SS around corners with more confidence. When I drive it hard around corners/curves is like a fast go-cart on rails. Love it
#397
