air Pressure sensor ???
Old 08-12-2008, 05:36 PM
jmarines's Avatar
Question air Pressure sensor ???
Does anyone know how hard it is to remove the sensors from a stock 16" oem rim and install them on aftermarket rims? How are they mounted?
jmarines is offline
Old 08-12-2008, 05:54 PM
prod's Avatar
Im curious too. I know they can be transferred to new wheels, but how? Are they attached to the wheel with screws or a nut on the valve stem?
prod is offline
Old 08-12-2008, 05:58 PM
1Panel2NV's Avatar
Once the sensor is removed, the valve stem can be removed like regular one.
1Panel2NV is offline
Old 08-12-2008, 06:01 PM
marksand's Avatar
Sensor is actually two parts: valve stem and sensor. When shopping for wheels or tires, make sure the house doing the installation of the tires has valve stems in stock for the sensors. Mine didn't and had to go on a wild goose chase.
Also, make sure to let the tire tech know you have sensors in the wheels. You don't want them to old school the old stems by jerking them own to quickly deflate them; in doing so, they will ruin the sensors.
Sensor screws into the bottom of the valve stem inside the wheel after the stem is installed. Each stem comes with a new screw. It is recommended that the screw is replaced each time the stem is replaced.
Hope this helps.
Edit:
A picture speaks a thousand words!
marksand is offline
Old 08-12-2008, 09:11 PM
jmarines's Avatar
That helps alot.... thanks... My local discount tire wants to charge me $80.00 to install them on my new rims..
jmarines is offline
Old 08-12-2008, 11:47 PM
marksand's Avatar
I was charged an extra $20.00. YMMV, as always. That put $5/tire. At $80, that is $20/tire. Time for more shopping!
marksand is offline
Old 08-14-2008, 03:25 PM
jdmcomp's Avatar
I ordered new wheels and tires from Tire Rack and had them install the sensors at the warehouse. I think I paid 40 each installed. They also balanced the tires after mounting. I do understand some alloy wheels require a different (longer I would think) tire stem.
jdmcomp is offline
Old 08-14-2008, 03:32 PM
ChevyMgr's Avatar
I hope I am not the only one who doesn't understand this.
What were you charged an extra $20.00 for?
I am sure YMMV is some sort of internet abbreviation for something, but what does "That put $5/tire" mean?
Maybe once I understand YMMV I will understand the post.
Sorry to be such an internet lingo dummy, but I didn't care to take the time to read the book.
ChevyMgr is offline
Old 08-14-2008, 05:08 PM
Cajun's Avatar
"Your Mileage May Vary"
Cajun is offline
Old 08-14-2008, 05:17 PM
ChevyMgr's Avatar
Oh, okay now it's clear as mud to me.
ChevyMgr is offline
Quick Reply: air Pressure sensor ???
