Going bigger
Going bigger
i just switched from 16" to 18" ..and i notice that the car seems a little sluggish accelerating, seems as if the bigger tires requires more work for the car to move lol i went stock size of the SS to not throw off the speedo ..so is this normal?
When the overall diameter of the tire is the same as before then the upsizing is not to blame for a loss of acceleration. Tread pattern can cause a loss of acceleration. Added weight of the rim and tire can also cause losses. On the flip side the tread design of a given tire can also give you better acceleration and if the new wheels are lighter then they too can give you better acceleration.
It sounds like either the tread pattern of the new tires or the weight of the wheels/tires or a combo of the two are causing your loss.
I can't imagine that the SS rims would be too much heavier then the stockers but they could and tires do vary in weight just like rims do to. Tread design will influence rotational friction and might be your cause. My 20's actually gave me better acceleration over my aftermarket 16's that cam with my car. The tread design was probably the biggest cause but even the over all weight of the 16's (with the tires on) were heavier then my 20's.
