Help me find these rims
Old 06-20-2009, 08:48 PM
1MEANHHR's Avatar
Does anyone know what type of rims these are and what size tire and rim combo I would use for this. It looks like the metal GM rims but they look deeper.Any help would be much appreciated.
1MEANHHR is offline
Old 06-20-2009, 09:09 PM
SHADOW(IN)'s Avatar
They look ( from this view ) like the rims on the GMC van that was used in the Hit TV show THE A TEAM .
SHADOW(IN) is offline
Old 06-20-2009, 09:19 PM
DLVRNIT's Avatar
Better Pic:
Hope this Helps,
DLVRNIT is offline
Old 06-20-2009, 09:22 PM
Keep in mind that that HHR had WIDE fendors added. Those would never fit on an HHR that had stock fender wells. To my knowledge Teazer never sold any and have long ago stopped offering them.
GDZHHR is offline
Old 06-20-2009, 09:31 PM
1MEANHHR's Avatar
Well back to the drawing board thanks for the help
1MEANHHR is offline
Old 06-20-2009, 09:55 PM
09 Panel's Avatar
Check with Diamond Wheels
http://www.diamondracingwheels.com/
They make all sorts of steel wheels and you can get them to make up almost anything you want.
09 Panel is offline
Old 06-20-2009, 10:28 PM
JB1
JB1's Avatar
those look american racing AR 767 wheels painted red
JB1 is offline
Old 06-20-2009, 11:10 PM
tireman1554's Avatar
Keep in mind that HHR is a total makeover from the ground up. Tube frame rear wheel drive and all. Someone here had posted a video of the build. It was built on NASCAR platform I believe. Being RWD those wheels will fit all day long and never would fit on FWD with that offset and backspace.
tireman1554 is offline
Old 06-21-2009, 10:13 AM
xzombiex66's Avatar
Someone posted some Nascar wheels on here some time ago in the 5x110 bolt pattern. Looked pretty similar to those.
xzombiex66 is offline
Old 06-21-2009, 04:59 PM
1MEANHHR's Avatar
Thanks for your help everyone just one more question, if I find a wheel I like , as long as its 5x110 bolt pattern will it fit or what other factors do I have to look for,does the offset have to stay under a certain number and for the 17 or 18 inch rims what are the widths I have to be concerned about?
1MEANHHR is offline
Quick Reply: Help me find these rims
